Sport Quads Discussions on sport quads.
piston slap!! HELP!
Old Apr 18, 2005 | 11:05 AM
kfx400kawasaki's Avatar
Default piston slap!! HELP!
Here's the story, One day I herd what I thought was valve train noise, when idleing I herd click click click click. Any way I thought that I just need to adjust the vales, so I took it to the dealer to check and adjust the valve clearance. So I got my quad back and they said that they went into the head and said that the clicking noise was not the valves, it was that the piston was slapping the head. The only wat to fix this, he said, was to bore it .40 over or something. He said this because, my cylinder was opening up.
I need help on what to do, should I just but a 440 kit w/ sleeve?
Any help/opinions would be greatfuly apreshated, thanks. [img]i/expressions/face-icon-small-frown.gif[/img]
Old Apr 19, 2005 | 05:52 PM
660Rryder's Avatar
Try replacing the wrist pin and bearing. If not then replace the rod with the stock stroke legnth. It sounds like your piston is clattering up and down too far. Like a wheel bearing gone bad its wobbling (the piston) thats the only way i can explain it. Plus if you have to bore it your rod (if aftermarket) will be stronger and more able to stay up with the task.
Old Apr 19, 2005 | 09:39 PM
Thanks, I'll tell'em that.
anyone else.
Old Apr 25, 2005 | 05:39 PM
bluenuts's Avatar
My buddy has a KFX and had this same similar noise. It turned out that the timing chain was stretched all the way out and the tensioner, located on the top right rear of the cyclinder was full extended in.. He put a new timing chain in it and it stopped the noise...Now though he has a problem again, thinking it was the valves he bout a shim kit and adjusted them out. This didn't help...the dealership told him that the KFX is know to stretch the valve stems! Looks like a rebuild now!
Old Apr 27, 2005 | 10:53 AM
What motor mods does he have? (If any)
Old Apr 27, 2005 | 06:32 PM
bluenuts's Avatar
It has only been jetted, no internal motor mods.
Old Apr 27, 2005 | 07:26 PM
blackbird's Avatar
bluenuts is right about the cam chain being bad,but if it is that i would buy the h-d DID chain not a factory one. and i would look at the athena kit for the kfx/z .comes with a new cylinder ,no boring
Old Apr 27, 2005 | 08:00 PM
sandpit's Avatar
What he said.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Apr 28, 2005 | 12:07 PM
bluenuts's Avatar
Yep...I've heard this from alot of guys with the KFX, on the other hand i haven't heard of any Z400's with the cam chain problem.. go figure, same motor!
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
