rancher water in rear drum
Old Apr 19, 2005 | 12:59 AM
LittleBill's Avatar
Default rancher water in rear drum
have 4 inches of water in rear drum, 2 inches of mud rear brakes became pratically useless, looks to be the rear dust seal? anyone else have a issue with the ranchers brakes?
Old Apr 19, 2005 | 02:03 AM
reliv007's Avatar
sorry cant help with that ? but I have a ? about the 424 unlocker. Does it work well and have you had any problems with it, if so what were they?
Sorry that was three questions!
Old Apr 19, 2005 | 02:48 AM
Gimpster's Avatar
Little Bill ---
I sent you a PM
----- Gimpster -----
Old Apr 19, 2005 | 08:46 AM
TRIPLELSTROKER's Avatar
I havent had trouble with the rear brake yet, but I do have to remove the front drums and clean the brakes and re-adjust them about every 3 or 4 weeks it seems. I play in the mud a lot and it works its way through the seals and like you said, the brakes become useless. I dont know why it hasnt managed to get into the rear on my Foreman yet. The last time I cleaned the front ones I coated the rubber seals around the lug studs with rubber silicone and they havent gotten water in them since. Thats been about 4 weeks now. Let us know if you find out where its getting in your brakes from.
Old Apr 19, 2005 | 09:28 PM
Gimpster's Avatar
Yes, the Brake panel seal can get ruined by something wrapping its self around the hub, like bailer twine, barb wire, vines etc...
A good point LittleBill brought up during our PM's was the fact there is a drain bolt on the back side of the brake backing plate, that should be removed to check for moisture. If a lot of water is noticed after removing the drain bolt, the brake panel seal is normally the problem. If caught soon enough it will save a lot of rear brake headache...
-----Gimpster -----
Old Apr 20, 2005 | 02:59 PM
reliv007's Avatar
how long does it take to drain?
Old Apr 20, 2005 | 05:58 PM
heatseeker8's Avatar
Reliv You dont own a quad...you ride illegally (on the back of a single passenger quad) AND you steal someones avatar..Please get a quad then post your findings..and stop riding illegally..your giving us a bad name.
Old Apr 20, 2005 | 07:22 PM
reliv007's Avatar
hey i dont ride illigally i have permission so .... HA
And i didnt steat the avatar there was nothing saying please dont use my avatar! If the person I BORROWed it from asked me to change it I would gladly do so!
And as for the " Reliv You dont own a quad, Please get a quad then post your findings" remark I am planning to buy a 2005 Honda Rancher4x4 in October 05 either ES or S havent chosen that yet
SO ..... dont be mean
Old Apr 20, 2005 | 07:26 PM
hondariderAR's Avatar
the law doesn't give people special permission...sorry.
and didnt u say u were getting a different not long ago?? it was some 2wd..i bet ur mind will change again..
Old Apr 20, 2005 | 11:21 PM
reliv007's Avatar
Yeah I wanted the 05RancherS 2x4 but then I decided that if I were to get the 2x4 model I would just be wishing I had 4x4!
I then decided to get the 05 RancherES4x4 cause I can get a WARN 424 unlocker!
