500 sportsman dying
Old Apr 19, 2005 | 09:24 PM
SPORTSMAN70003's Avatar
Default 500 sportsman dying
I fixed a friends 97 500 sportsman today and it has a problem of dying sometimes when I put it in reverse or the fan kicks on. I replaced the stator,flywheel,coil pulser,recoil,& cdi box because they were bad. It has been setting awhile and the battery is pretty weak could that be the reason its dying? Also they are what looks to be a ground that is not hooked to anything but looks like it would be the right length to connect to the battery ground could this be the cause of it dying?
Old Apr 20, 2005 | 01:31 PM
Well I've been play with it today and if you push the reverse overide in it will not die when you put it in reverse. Also if you push the awd button in and the try to turn it off it will die but if you let out on the awd button real slow it will stay running. I need some help please anyone got any ideals? O yea I also hooked the ground wire that was loose up to the battery ground and it didn't help.
Old Apr 20, 2005 | 02:08 PM
CORNYfeces's Avatar
I have a Sportsman 500 also and it went through that. For me the problem was at the very front of the ATV under like the "hood" there is a wiring harness. The charging system is there and one of the wires was rusted and eaten through. I replaced those and its great now... Just a thought
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
binky79
Jul 30, 2015 06:37 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 4, 2015 06:13 PM
