Raptor carbs, float level and clear tube method explained.
Old Apr 19, 2005 | 09:32 PM
86LT250RFatty's Avatar
Default Raptor carbs, float level and clear tube method explained.
Freez Wrote this i am just putting it on here for people to see its great and works!
I have a similar post on how to set up the carbs correctly, but I found that some people got confused and some of the pictures also got lost on the old post.
So here goes.
I will also start with the basics on how to get started.
Remove all the plastics on the front of the bike. Next remove the fuel tank and the air box. Make sure you close the fuel delivery before you remove the tank.
For those of you that would like to know what mods to do to the airbox to get it flowing correctly read on. Cut out the rubber flaps inside the snorkel. The Snorkel should have no restrictions if you look inside it. Then cut additional plastic out of the airbox lid where the air flows into the airbox. Look at the picture below to see how to cut it. It opens the air intakes a little more. Some people cut all of it out, but I left some of it behind. The theory is that if water comes into the intake, it will bypass most of the filter and the water will collect at the back of the airbox.
For more airflow you can cut two 50 mm holes into the back of the lid. This is a similar mod recommended by Yoshimura and it works well. I installed two pipes into the holes that run down ½ to 2/3 down into the airbox. This was done to help prevent water form getting onto the air cleaner. Please note that it will increase the chances of water getting into the airbox, but this mod with the pipes will keep water away from the air cleaner much more than without a lid. Then other people remove the lid completely. If you run in wet muddy conditions, run with the lid. It’s up to you how you want to modify it. YES you have to rejet with these mods. Most people also install a 25 Pilot jet to get the idle mixture right. The number of turn on the airscrew will depend on your mods. Anything from 2.5 to 3.5 turn should do the trick. Play around till you have a good setting. Now for a warning. Some people, including myself have found that with the open lid the bike will have a slight low RPM stumble. I have not been able to fix it. The problem is caused by pressure waves inside the stock rubber intakes between the carb and the airbox. This pressure wave causes the sliders inside the carbs to move erratically and it causes a slight stumble. This only happens with very small throttle openings. If you open the throttle a little more it goes away. Its not a major problem, but be aware of this.
See a picture of the additional mods below.
For those of you that need to know how to remove the needles. The picture below shows the plastic tops on the carbs removed and what you will find underneath them. Be careful when opening these lids. There is a spring underneath the lid and it will jump out of you are not careful. Do one at a time, so if you get things wrong, you always have another one as a sample.
The below picture shows how it looks like with the needles removed. TAKE note of the small little springs. They get lost very easily. I like to take the whole slider and put it upside down on a table. Needle facing upwards at you. Then softly press down with your finger on the needle, taking care not to press to hard, until it clicks. When you turn the slider back up, you will find the little spring laying there waiting for you. In the picture you will also notice two set of slider springs and needles. The ones on the left are stock, the ones on the right comes with the dynojet stage 2 kit. The Dynojet needle on the right is much sharper and has 6 different setting, compared to the thicker stock needle with 5 settings. You need the needle in the 3rd clip with the stock setup and the 4th clip with the dynojet needles. Moving the clip towards the sharp end, will enrich the fuel mixture. Moving the needle away form the sharp end will lean out the fuel mixture.
When you are done with the needles put them back the way you took them out and put the plastic caps back on the carbs.
Next remove the carbs. I did not take the throttle cable out. It is possible to work with the cables attached. Put a bowl under the carb before you turn it upside down. When you turn them around fuel will drain from the carbs. Below is a picture of the carbs upside down. You will notice a clear tube on the one carb. It will be used for checking the floats at a later stage. You need to move the clear tube between the carbs to check both float levels. Keep in mind that they will only be used when the carbs are mounted back on the motor.
Remove the float bowl. You have 4 screws on each bowl. Take note, these screws are very soft and strip very easy. Use a nice big screwdriver that fits the screw perfectly. To small and they will strip. Good advice is to get new steel screws of you can. Also take special care when you tighten them later. The picture next to it shows different coloured arrows.
The red arrows are for the fuel mixture. Turn them in until they are seated. NOT TO TIGHT. Then turn them out 3 turns. (I used the dynojet stage 2 kit settings. It might be different for other jets). You might have to do final adjustments at a later stage to get them perfect.
The Blue arrows point to the floats. More later.
The green arrows are pointing at the main jets. More later.
The yellow arrows are the Pilot jets. With the dynojet kit they don’t recommend that you change them, but I personally changed them for bigger pilots. I had to order them separately. With GYT-R, you get them with the kit.
The below picture shows one of the main jets removed. I had to replace them, because of the airbox mods I have done. Note there are 3 peaces to this “jet” Use a small spanner to keep the 3rd peace in place. You should only remove the top two peaces. Notice them lying to the left hand side of the carbs. Replace the main jet if required and put them back the way they came out. Again use the right screwdriver. To small and it will cause damage to the jet. Don’t tighten it to much.
Now to check the float levels. Please follow this exactly! To start do the following. With the float bowls removed turn the carbs upright. (the same way they are mounted on the motor) The floats are now hanging fully opened. Now slowly start turning the carbs to 90 degrees with the openings that connects to the motor facing down. Move the carbs between upright and 90 degrees and look at what the floats are doing. When the carbs are nearly at 90 degrees you will notice the floats move and suddenly pause. It will pause for a little and if you keep turning it will start moving again. You need to find where it pauses and hold it there. It is the position where the floats touch the needle valve pin. Measure between the split (place where the float bowl and carb comes together) and the little shoulder of the float. It should measure 13 mm. The image is showing you how to hold the carb in the right position to measure the floats.
Note the measurement in the picture is slightly off.
The floats on my bike were out so I had to adjust it. The level was to high. If you need to adjust the level, you need to take the floats off. There is one screw that holds it in place. Remove it and off comes the floats. A small little needle valve will be dangling on the float. Take care of it. The picture below shows it apart.
With the floats off, you will notice a small little metal thingy at the back of the floats called a tang. You need to bend it to get the right float level. Bending the tang down towards the bottom of the float will lift the float level. Bending the tang towards the top of the floats will lower the float level. Adjust it, put it back in the carb and check if it measures to 13mm. Make sure you measure it as explained above. PLEASE NOTE. The 13mm measurement is pure a guideline. See the clear tube method later in the post to make 100% sure the float level is correct.
I had another problem. After adjusting the floats to 13mm the floats would not open correctly and restrict fuel delivery. You can test to see if you have the same problem. With the floats adjusted correctly and fitted in the carbs, turn the carbs upright and hold it there (Same way as they are mounted on the motor). Now blow into the fuel pipe that connects to the fuel tank. It should flow air very easily. Make sure that both carbs are flowing. Press each float softly upwards till it stops flowing air. If you let go of the float is should flow air again. If it does not flow air, or has a restricted flow, you have a problem. You need to mod the floats. It should flow easy, but keep in mind there is only a small little hole. To be safe it will not hurt doing the float mod anyway.
The picture below shows the float level mod. Take a small little file and file down the little plastic stopper at the back of the float. DON’T shorten it. Take a 45 degree angle off it. Take note, it should look like the float below. The screwdriver is pointing at the little stopper.
After this mod it should open real easy and you should have no problem blowing thru the fuel intake pipe when the carbs are the right way up.
When this is done and the floats are set correctly, put the carbs back together. Take note not to tighten the screws to much. When the carbs are all back together and you need to putt them back, I found that I struggled with the rubber intakes on the head. To prevent it from sticking to go back in, make sure the clamp screws are loose all the way. Then dip your finger in some fuel and rub it inside the intake. With the fuel still wet, the carbs will slide in real easy.
Clear Tube Method
Now to check the float level with the carbs in place. This method will make 100% sure the float levels are right. You don’t have to tighten the clamps on the rubber intakes to check the float levels. Do that once the level is correct.
1st put the fuel tank back, again don’t worry about tightening it up. Connect the fuel intake hose from the carbs to the fuel tank and open the little tap. The fuel should now flow into the carbs. Check for leaks. If none, you check the floats using a clear tube. The size of the clear tube must just fit the little drain hole on the bottom of the carb. I showed you before where this pipe connects. The picture below shows you the clear pipe and the screwdriver is pointing to a small drain screw on the bottom of the carb. Point the clear tube up and above the section where the carb and float bowl joins. Open the drain screw and you should see fuel run into the pipe.
When the fuel stops flowing, tap the pipe a little to make sure there is no air bubbles trapped inside it. Push the pipe against the carb and the fuel level should be 3mm above split between the carb and the float bowl. When this is done close the drain screw. You will have to move the clear tube and go to both sides of the bike to check the two carbs. Don't try checking it from the same side. See picture below. PS. my finger is not pointing at the fuel level, it is only holding the pipe in place.
If it is not correct you have to bend the little tang on the float up or down to get the level right. 13mm as explained above work almost all the time, but I have had some cases where it needs to be at 14,15 or even 16mm to get the clear tube level of 3mm right.
When you are happy with the results, tighten up all the clamps, put it all back together and make sure there is no bolts and nuts left. PLEASE NOTE. When you tighten the rubber intakes onto the carb, they sometimes move and cause gaps and little air leaks. Make sure they are mounted correctly and they are not pushed open by the clamps.
Hope this explains more clearly how to get the carbs set up right and you find it useful.
Ok, Freez wrote this, over at blue*traxx. been some discussion about the float levels and so on so i thought some people might find this usefull. thank freez for this he did it all.
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
