yamoto 110 problum check your
we went to pismo for 4 days and had a blast but my sons 110 stopped running on the second day { good thing we brought a extra one } it had spark and gas but no compretion.i took it apart today and found that the piston and the head was all scard up the, cylinder walls are fine.and the exhoust valve was the compretion problum.it looked like some thing got sucked in. so i started searching and took the carb off and the butterfly for the choke fell out and the little screw was gone { well not gone it's smashed all over the head and exhaust valve }so you may wont to check you screw in the carb.
PS the tires don't work very well in sand i may dismount them and turn them backwards[ thay just dig. with that small HP you need to stay on top.
Your not having any good luck with these are you? Knock on wood but I have about 30hrs on my sons Kazuma 110 and it is still running great. Is yours going to be covered under warranty?
KimSJoh
14
Jul 18, 2015 07:20 PM
