727 Raptor piston......
Old Apr 21, 2005 | 09:59 AM
Rider1169's Avatar
Default 727 Raptor piston......
Im looking for a 11:1 or so compression 105mm piston for the raptor. Where is a good deal on them? So far i have only found the trinity stage 4 for 250$ish. Any better brands or places for this 727 piston?-----Rider1169
Old Apr 21, 2005 | 12:13 PM
FarmStud's Avatar
Lots of happy craycraft and kenz people on here. I'm sure either place could help you out.
Old Apr 22, 2005 | 04:07 AM
CTracingraptor's Avatar
yeah get ahold of kenz or craycraft, PM if you want their number. I dont recommend the trinity, for one reason, trinity has all of its pistons matched to trinity heads. the top part of the head is shaved to get the correct comression.
Old Apr 22, 2005 | 05:50 PM
bl4cksh337's Avatar
i dont know how set you are on going for the 727 but i personally think that you souldnt go for the 727 unless you dont plan on having your quad for a while. or two are going only for drag. Go with the 686 just in case you had some kind of accident and blew your motor. I know its nothing easy like blowing a motor on a 2stroke but just in case you switched twice down because of a bump or something. You know that way you at least got a backup plan besides new motor.
Old Apr 22, 2005 | 08:52 PM
Rider1169's Avatar
Well, im building it up for a senior project. Im just looking for a piston under $250.
Whole 727 project parts list
-Local machine shop 727 bore
-LA sleeve 105mm 727 sleeve
-11:1 727 piston (not determined what brand or from who)
-Modded stock carbs
-Wiseco crank shaft
-Wiseco Connecting rod
-Hotcams stage 2
-Kibblewhite Titanium valvesprings
-Mild port job
-And all the little fill-ins
Ill be using it just for rec use, fast trails, track, dunes, whatever. I hopefully will be able to smoke a few buddies when its all set up.
Old Apr 25, 2005 | 02:18 AM
686raptor's Avatar
je pistons is what we run on a 686 and a 727.
Old Apr 25, 2005 | 03:22 PM
Rider1169's Avatar
How are the JE pistons? i remember reading bad things about them a long time ago, but im not sure if it was isolated problems or they have fixed their problems or what.---Rider1169
Old May 6, 2005 | 01:23 AM
madracing's Avatar
rider problem not fixed we dad one crack 2 months ago. we sell CP pistons now 260ish. think about a 720 stroker 102mm bore revs quicker pm for details
Old Jul 25, 2005 | 10:02 PM
dragraptor's Avatar
call up vitos or craycraft,i prefere craycraft
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
