650/rear brake
has anyone had a problem with the rear brake(pedal).on the 650,i'm on my second master cyl.cat doesn't make a rebuild kit you have to replace the whole unit.always full of fluid but no pressure at all.
Either the fluid has dirt in it or the fluid is eating the seals. If you take it apart you will find it is full of "o"rings, just that the parts to the local car parts store and they should be able to fix you up.
my back brake dose not work at all either. My dealer told me it was just a bad design but that i could up grade it from with the back brake system from the 05's. Besides that have you had any other problems with your 650 (beside limp mode)? Overall are you happy with it?
oliveiracarlos
Sep 7, 2015 03:39 AM
