**HELP**Warrior wont start ***QUICKKKKKK***
Old Apr 21, 2005 | 05:20 PM
redneckcav24's Avatar
Default **HELP**Warrior wont start
My 01 warrior only clicks when i tried to start it. I just put brand new battery in 10 mins ago. wire connections at battery is fine. I have tapped the solenoid but that didnt work. Any suggestions????????? Please help me get this done before dark which is about 4 hrs. away
Old Apr 21, 2005 | 05:22 PM
holeshotz8436's Avatar
sounds like the starter is bad, try pushing the start button and tapping the starter at the same time. not shure if the warriors have either but just try to kick/pull start it
Old Apr 21, 2005 | 05:23 PM
Default **HELP**Warrior wont start ***QUICKKKKKK***
Let me try that. No they dont have the kick or pull start but there is a spot to put a pull start.
Old Apr 21, 2005 | 05:29 PM
tell me how it works out, also if your really desprite to ride your warrior just have someone give you a pull or find a hill to pop start it
RacinJason's Avatar
it sounds more like the starter switch(solinoid)
you can bypass the switch by jumping the current from one post to another like you might on a Ford truck with iether screwdriver or pliers
Old Apr 21, 2005 | 05:53 PM
Ok i just tried the starter thing and it just made a weird noise and sparks flew. I know i can pop start it but i want to get it fixed or find the problem. i will try bypassing the current and see what happens.
Old Apr 21, 2005 | 06:44 PM
thats not really good, where did the sparks come from?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
