Sport Quads Discussions on sport quads.
jettin changes in different temps??
Old Apr 22, 2005 | 01:09 AM
yamaharaptor350's Avatar
Default jettin changes in different temps??
i have a 138 dynojet in my quad now and everything is fine and the weather has been warm... when it gets colder like winter cold will i have to put a bigger main in??
Old Apr 22, 2005 | 12:09 PM
nuthin??[img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 22, 2005 | 08:21 PM
blackbird's Avatar
yes ,cool air is more dense than warm air so you want to run rich in the winter.every 20 degrees down you bump up the main
Old Apr 22, 2005 | 09:10 PM
if ya had a stock quad... stock jetting y would u not have to jet it in different temps like u do with a quad with a exhaust on it and jetted
Old Apr 22, 2005 | 09:31 PM
haha how many people really jet there quads every 20 degrees drop
Old Apr 23, 2005 | 01:15 AM
hondabuster's Avatar
Almost all quads and motorcycles are jetted lean on the idle circuit and rich on the main, right from the factory. This allows the motor to meet emissions and provides a saftey factor for when someone runs wide open. There should be enough of a saftey factor, that when the air temps drop, the motor wont be too lean at wide open, but will definetly be too lean on the idle circuit. This shows up as hard starting, needing a long time on choke, poping thru the intake when cold. Usually just a 1/4 to 1/2 turn of the mixture screw is enough , to enrichen the idle when cold, and coming back that 1/4 to 1/2 turn when the weather turns warmer ,stops the idle mixture from being too rich in the summer..
Keep an eye on the drivability symptoms, which are listed in this article, and youll know if its too lean or not.
jetting and symptoms
Old Apr 23, 2005 | 02:16 PM
thats really helpful man thanx
Old Apr 24, 2005 | 02:22 AM
Vunit's Avatar
i got mine jetted last summer by my dealer for the first time when i got my pipe...i ran it this whole pass winter and now the spring without changing anything..i dont know but my quad seems to run prefect in any type of weather conditions.. it always starts fine and never gives me any trouble... i never have to mess around with the jetting or nothing...on the other hand my friends quads which are jetted also there quads take longer to warm up in the winter and dont run good until they get really warmed up during in the winter times as of mine it run 100% all year...
Old Apr 24, 2005 | 11:34 AM
yea thats y i asked cause most of my friends and I just jet there quads once and thats it and they have never had a problem and ride it all year round thanx for the input guys
Old Apr 25, 2005 | 05:35 PM
bluenuts's Avatar
Mine runs great in winter or summer doesn't matter. I run a 150 Dynojet main in mine. The only time i think you would need to change the main jet is if you take a trip somewhere with a drastic elevation change from where you usually ride!
