RECON wheel pattern
Old Apr 24, 2005 | 01:06 AM
ixRAZORxi's Avatar
Default RECON wheel pattern
I need to know the wheel lug pattern of a recon front and rear rim.
Will 10" rims clear the drums on the front?
Thanks for the help
Old Apr 24, 2005 | 01:09 AM
KNOWSALOT's Avatar
The Facility
It's same as the other Honda utilities....4/110 on the front and back.
Regarding your 10" wheel on the front, I am not so sure about. If it does work, you will be lucky. Maybe someone who has tried it will post.
Old Apr 24, 2005 | 10:07 AM
moto93's Avatar
Yes, 10" rims work on the front. I run stock aluminum wheels off an '87 250x on mine. Isn't stock size 10" anyway?
Old Apr 24, 2005 | 10:36 AM
KNOWSALOT's Avatar
The Facility
moto93,
The 250X uses the sport quad bolt pattern on the front and will not fit a recon at all. Stock size is 11" on the Recon.
Sure you don't have these mounted on a 250EX rather than a Recon??
Old Apr 24, 2005 | 11:19 AM
ixRAZORxi's Avatar
I tried 250ex rims and they don't work on the front.
So all utility hondas are 4/110?
I want to go with 10's all around. Stock is 11 up front and 9 in the back. It looks stupid.
Old Apr 24, 2005 | 12:31 PM
TRIPLELSTROKER's Avatar
The front wheel pattern is different on the recon and sportrax from the other utility quads by honda. The front wheels on the sportrax is 4/144mm and the rear is the same as the other quads 4/110mm. The only reason I have ran into this is because I replaced the factory wheels and tires on our sportrax with itp mags and sold the old tires to a guy that had a recon 250.
Old Apr 24, 2005 | 12:36 PM
P.S. The fella with the recon couldnt use the front rims from the Sportrax becausse of the difference in the lug pattern. He used only the tires. If I remember correctly the recon he owned was like all the other Honda Quads with the 4/110 pattern all the way around .
Old May 26, 2006 | 05:40 PM
Cacheola's Avatar
Has anyone found the answer to this yet?
I need to change out those Dunlops in front for the Razr2s. The rim would need to be changed to a 22 10x5. Anyone done this sucessfully?
Moto93 can you expound?? Do you have a 250 Recon? Did you replace the front rims?
Old Jan 15, 2007 | 10:44 PM
moto93's Avatar
If anyone is still wondering... '87 250X (4x110) front wheels do work on a Recon. I can take pics if you like.
SMC
blueandy88
Sep 7, 2020 03:11 PM
meddy0388
Sep 9, 2015 06:41 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
blueandy88
Aug 30, 2015 08:26 PM
