250x/300ex
Old Apr 25, 2005 | 03:58 AM
lucky6man's Avatar
Default 250x/300ex
i have a 250x heres my problem its kind of a pain to get started once its started it runs fince at higher rpms if i try to lower the idle speed it will shut off or when i let it run on its own for a min with out bliping the throttle. the engine will all a sudden just wind down and shut off. sometimes it will run longer then others befor it does this. any ideas on what it could be? thanks
Old Apr 25, 2005 | 04:07 AM
lucky6man's Avatar
Default 250x/300ex
wanted to add something i left the fame with all the stuff on it cdi coil etc out side all winter long. so it could just be a weak spark does that make sence? if so what ones should i check stator coil or cdi for the peoblem?
Old Apr 25, 2005 | 10:00 AM
iwannaride2's Avatar
Default 250x/300ex
it is prob. just your carb....a lot of x's have been having problems with their carb from what i noticed...mine did that a lot too...i had to clean the carb...
Old Apr 25, 2005 | 11:52 AM
lucky6man's Avatar
Default 250x/300ex
yea iv already taken the carb apart and blow the jets out with the air hose. still not working
Old Apr 25, 2005 | 11:54 AM
Dirtmomma's Avatar
testing testing 123.
Default 250x/300ex
I would clean the carb & adjust your valves [img]i/expressions/face-icon-small-smile.gif[/img] out of adjustment valves & it won't want to idle well!! I'm in the same boat w/ my 300 right now, in the process of trying to dail it in, but I run a 400ex carb on mine, it ran fine for 6 months then it all went to hell in a handbasket LOL [img]i/expressions/face-icon-small-wink.gif[/img] naw just a really dirty carb & jets but the valves will be next!!
hrc200x
ATC 3-Wheelers
Sep 24, 2009 08:43 AM
hrc200x
Feb 27, 2003 01:41 PM
ModdedX
Oct 9, 2002 01:48 AM
honda205X
Nov 25, 2001 02:53 PM
honda205X
May 24, 2001 05:54 PM
