few problems/questions with a 400ex
Old Apr 25, 2005 | 01:04 PM
monster88's Avatar
Default few problems/questions with a 400ex
I just went quadding this weekend and i have a few questions. My first question is... when i ride its really hard like to ride. Let me explain. All the feedback from the bumps and stuff from the front goes right up to my arms and it just like hurts going fast over bumps. My friend told me i may need a new steering stem and a ball joint. Is it hard to install them? I think i also need new front shocks, cause there shot. Where exactly can i get front shocks? I dont need anything special, im sort of low in cash. Stock shocks would be fine... Does anyone know where i can find them online? Any answers would be great. Thanks guys. Also, he told me to look at lonestar steering stems. He said if they ever break... then u just ship it back and they replace it for free.
Old Apr 25, 2005 | 04:00 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://www.off-road.com/atv/suspension/shockadj.htm
First, you need to be sure your shocks (front and rear) are properly adjusted. The stockers in front are only adjustable for preload, the rear is adjustable for preload, as well as compression and rebound damping. The EX has pretty descent stock shocks, so it sounds like your shocks may be adjusted to stiff, or they may be blown. Try adjusting them, then get back to us.
Maybe try some riding technique as well. The EX wheelies easily, so try lofting your front end over obstacles, rather than hitting them head on.
Old Apr 25, 2005 | 04:40 PM
polarsport500's Avatar
chris, the front shocks arent shot their set stiff for my weight. jsut adjust them and ull be okay
Old Apr 25, 2005 | 04:53 PM
monster88's Avatar
o and 1 more thing, i cant get it into neutral when its running but when its stalled out... i can get it into neutral. Its easy to get it into neutral when its stalled but i cant get it when its running. IS there a ajustment or something?
Old Apr 25, 2005 | 05:54 PM
u sure u have the clutch pulled in all the way when its running? cuz that would be the only problem.. the clutch isnt fully engaged to let the tranny go into neutral
Old Apr 25, 2005 | 10:28 PM
monster88's Avatar
yep i had the clutch pulled in all the way. It does not shift into neutral. I have the clutch pulled in all the way when its stalled and it goes right into neutral. There is no ajustment?
Old Apr 25, 2005 | 11:01 PM
the only thing i think it could be is the tension of the clutch cable...try tightening the cable a bit and see if theres still trouble getin it into neutral when running. if anything u might just need a new clutch cable but thats like 10 bucks... itl also be alot easier to pull the clutch in with a new cable.
Old Apr 26, 2005 | 11:37 AM
monster88's Avatar
k np i will try and do that today.
Old Apr 26, 2005 | 01:26 PM
Vinson581's Avatar
if you cant get it in neutral, you have been riding the clutch alot i bet, and you burnt the metal friction plates, so they are a bit warped, get a NEW clutch kit, and it will remedy the problem, alot of people do this i have seen of friends bikes, and thats always the problem.
v581
Old Apr 26, 2005 | 07:25 PM
monster88's Avatar
ok, i was working on it today, and i noticed when i pull in the clutch all the way like sqeeze hard, i can get it into neutral. But if i squeeze it normally when its stalled, i can get it into neutral with np... Do u think its a ajustment or those plates? How do i ajust my clutch?
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
