400 ex oil level
Old Apr 25, 2005 | 11:09 PM
Dirtpig's Avatar
Default 400 ex oil level
Once the oil has been changed in a 400ex and 2 QTS of oil added , about where does everybodys oil level show on the dipstick after a warm up and a couple minutes wait........mine is about halfway between the upper and lower marks
Old Apr 26, 2005 | 12:42 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
That is about right. The whole system holds 2.3 quarts.
See my comments in this post. I think it will better answer your questions...........
http://forums.atvconnection.com/mess...did/450411.cfm
Old Apr 26, 2005 | 12:27 PM
prudog's Avatar
What year is your EX...I have an 03, and it calls for 1.8 quarts of oil after the oil and filter change. According to the service manual....when you check your oil, don't screw the oil stick all the way back in, just stick it in and read it...but yes, it sounds like you have the correct amount.
Old Apr 27, 2005 | 07:10 AM
Dirtpig's Avatar
Mine is an 2002 model........the owners manual calls for 1.95 Qts after an oil change............and yes I just sit the dipstick on the threads but not screwing it in to check level.....................seems like the 2.3 Qts would bring it to the upper mark without overfilling
Old Apr 27, 2005 | 10:39 AM
Red Rider
Are you guys forgetting to drain the cranckase? With the cranckase drained and an oil filter, 1.95 qts. hardly shows on my dipstick.
Old Apr 27, 2005 | 10:08 PM
Dirtpig's Avatar
By draining the crankcase to you mean by tilting it so more oil runs out of the drain plug hole.........and how much oil to you put in after this
Old Apr 28, 2005 | 06:08 PM
Dirtpig's Avatar
How bout it Recon ranger.............how much oil do u put back in your EX
Old Apr 29, 2005 | 12:08 AM
Red Rider
I just add until it gets to the top of the dipstick. Maybe like another 200-300 mL.
Beeline08
Nov 11, 2016 04:00 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
panicmanic
Sep 28, 2015 12:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
