95 Scrammy 400 Fuel Mix?
Old Apr 26, 2005 | 08:54 AM
dave59's Avatar
Default 95 Scrammy 400 Fuel Mix?
Hello, I would like to remove the oil auto mix on my scrammy. What is involved with this? Is it easy and what would the fuel mix be? I sure would appreciate any help on this. Also, could I then run a single line throttle cable? The 2 stroke scrammy likes to tear your frikin thumb off after a long trail ride.
Thanks in advance
95 scrammy 400
gold pipe, jetted and a ball to ride!
Old Apr 26, 2005 | 09:00 AM
POLARISFREAK's Avatar
You can get an oil injector block off kit from any of the polaris aftermarket companies, HPD or RCR. You could also just remove the pump and take the gear off the end of the injector shaft and reinstall the pump if you don't want to buy a blockoff kit. You can then get a single throttle cable. Mixing isn't bad, get a ratio rite cup to make things easier. Most will say on the oil mix anywhere from 32:1-40:1. I'd say 40:1 should be fine with your mods!
Old Apr 26, 2005 | 11:02 AM
oghma's Avatar
Removing the oil pump and putting on a block off kit is probably a 30 minute job tops. As for mixing I mix at 40:1
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
