2004 SPORTSMAN SQUATS BAD
Old Apr 29, 2005 | 11:52 AM
KINGSCLEAR's Avatar
Default 2004 SPORTSMAN SQUATS BAD
Hi I have the above bike and my buddies tell me when I take off my trailer hitch almost drags on the ground my bike squats so bad. I'm 220lbs and I usually have gear loaded on the back. When it gets going it returns to a some what normal height. can I adjust this some how shocks or something
Old Apr 29, 2005 | 01:44 PM
Elbongo's Avatar
You can adjust your rear shocks. Unfortunately, I dont' have any idea how you do this. I think they come from the factory at the softest setting.
Old Apr 29, 2005 | 02:52 PM
TreeDoc's Avatar
The preload is adjustable on the rear shock. The adjustment takes places on the bottom of the shock. Get under and take a look and you'll see an aluminum fixture that the spring settles in to. That fixture has a "stair step" adjustment which is done with a spanner wrench. The farther up the stair step you go the more pressure or "preload" is put on the spring. That should help some but you should still watch the weight of your load on the ***-end, it's a common charactoristic of IRS equipped Utes to squat a bit.
Old Apr 29, 2005 | 03:26 PM
KINGSCLEAR's Avatar
Thanks ,so they adjust just like the motorcylces used
Old Apr 29, 2005 | 04:16 PM
mtpockets's Avatar
KING, try going up 2 notches. that did the trick for me. it's still an A+ ride but no squatting now.
enjoy your new ride![img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 29, 2005 | 05:06 PM
Bill35's Avatar
And dont use a pipe wrench on it.Dont ask me why not to use one.And on the front you can use a spacer under the spring it really helps to hold the front end up....
Old May 3, 2005 | 01:49 PM
BIGDUCK's Avatar
My 98 xplorer came with one. I never have used it.
Old May 3, 2005 | 02:03 PM
jimmypsp700's Avatar
welcome to the forums!
my scrambler came with one too but for some reason the sportsmans do not.
Kingscleare,
you will need to lift the weight off the suspention to adjust with the spanner wrench.
jim
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 9, 2015 01:49 PM
