scrambler 500 HPD pipe and clutch kit
Old Apr 29, 2005 | 01:43 PM
badassz24ondubs's Avatar
Default scrambler 500 HPD pipe and clutch kit
hey all i am thinking about getting an hpd powermaxx exhaust system with the clutch kit they recommend. is it worth the $400+?? i am really starting to not like my 04 scrambler 500 because it just feels sluggish and what not.is this the kit for me or not?thanks
Old Apr 29, 2005 | 02:32 PM
BigBadScrambler's Avatar
Do you need a spark arrestor? If you need one where you ride then the HPD system wont fit your needs. If it doesnt matter and you want the best FULL system out there, then you cant beat it. The White Bros E-Series is a good alternative for a slip-on
Old Apr 29, 2005 | 06:12 PM
ftwflh's Avatar
Before I dropped that kind of $$$$ in it I would change the primary clutch to a polaris white or green and set the secondary at 2-2.You wont get that much of a gain from a pipe (a little but not head snapping)The clutchis where the power is hidden.
Old Apr 29, 2005 | 07:48 PM
2manytoys's Avatar
The 500 has plenty of power but you just need to tune the clutch to suit your needs. Like ftwflh said change the primary spring and it will be a different bike. It is the cheapest most effective mod to do that will get the most performance out of it. The spring is around $20 and very easy to install. Also get yourself a K&N filter for a little more snap.
Old Apr 29, 2005 | 09:19 PM
jimk72's Avatar
I did the same thing and it lasted the first year, after I decided to upgrade some more I sold the springs and upgraded. You can't beat the difference for 20-40$ (I got a violet secondary also).
If you have the money and ready to spend, get the clutch kit this year, ride it and you will get used to the difference, and then next year get the full exhaust.
Basicly you can get a clutch kit, exhaust, airboxmod kit(comes with new jets) and thats about it as far as performance(fine tunning is anouther story). If you look at it that way you can get 1 or 2 a year to break up the cost, or if you have the money now get it.
It will be a big enough difference that you will be happy but its up to you and how much you want to spend.
Old Apr 30, 2005 | 02:36 AM
Polaris500HO4x4's Avatar
check into the clutch kit and instead of exhaust, look at cams
Old May 2, 2005 | 06:37 PM
sandScrammy's Avatar
just wanted to let you know that I have the power max for my 04 scrammy. It has great bottom end, the only problem I've had it that the muffler fell apart!!! I hope hpd fixes it.
Old May 2, 2005 | 06:44 PM
XtremeSkier's Avatar
i know what thats like, ive had two HSP silencers fall apart on me. Just got my second one back in the mail last week and i think im gonna go put it on right now[img]i/expressions/face-icon-small-smile.gif[/img]
Proud Father
Aug 19, 2015 10:08 PM
mitchxc700
Aug 19, 2015 02:41 AM
mitchxc700
Aug 10, 2015 09:26 PM
JohnnySplat
Aug 6, 2015 12:07 PM
traumajunkie
Jul 23, 2015 02:10 AM
