Part question
This should be an easy question but I can't find the answer anywhere.
What size is the circlip that holds the bearing ring to the shaft on the axles
of my machine? I mangled one of mine pretty good yesterday changing
a CV boot and would like to have some on hand for next time.
thanks
thanks
Yes the clip at the very end that holds the ring with the bearings in
it from falling off the axle. It is called a circlip and you are supposed to have
special pliers to get it off. They look like needle nose but are bent at
right angles at the tips.They sell the circlips at the hardware store for
pennies but I need to know the size . I don't have the old one
because I bent it back as best I could and put it back on. I want to know what
size it is so I can have some on hand next time.
thank you
thank you
did u not get new clips with your boot..........if u did why not take that one down to the hardware store and see if u can match it up......also go to ac dealler and buy one then u can go and match it up ......
