p650 want start????
Old May 3, 2005 | 12:17 AM
WEEWEE's Avatar
Default p650 want start????
I have a 2003 650 Prairie that want start. It will turn over. I have replaced plugs, ECU, new gas, and battery. I have good spark all the way to both plugs. Good compression. Good fuel flow all the way to carbs when ignition switch is on(fuel pump is working). Hope someone may have some ideas.
Old May 3, 2005 | 01:10 AM
lackdog's Avatar
Want start? Whats "want" start LMAO! Do you mean won't start as in will not start? Have you sprayed in ether to see if it fires up for a second or two yet?
Old May 3, 2005 | 12:22 PM
tuffEnuf's Avatar
Make sure your fuel switch is on & getting fuel to carbs, battery fully charged, plugs not fouled. Prairies will definately not start till gas reaches the carbs.
Cycle kill switch from off to on, Put in neutral, turn off lights, turn on key wait 10 seconds (for gas to pressurize carbs), position choke full on and depress starter button. Should fire in 3-10 seconds. If it does'nt remove airox lid and try a shot of either. Close airbox & repeat. If still not start, try pull start. If it starts with pull start your battery is weak/dead cell.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
