350x Axle
Old May 16, 2005 | 09:02 PM
thebutelr's Avatar
Default 350x Axle
On my 350x the threads for the left axle nut are completely stripped, i mean some of it has actually been broken off. Is there any way i can have this fixed or do i need to start lookin for a new axle?
Old May 17, 2005 | 02:39 AM
ThrashAndCrash's Avatar
Default 350x Axle
Truthfully.......start looking for a new axle. It can be repaired properly by a dang good metal worker, but good luck finding one for cheap.
Old May 24, 2005 | 12:44 AM
dirtrider250r's Avatar
Default 350x Axle
Just get the new axle your better off. I just got a Durlablue HD +4 for only 250$ from www.offroadplus.com take a look
Old May 25, 2005 | 06:09 PM
thebutelr's Avatar
Default 350x Axle
Will a ATC250r, 250x, or a 400ex axle work for a 350x?
Old May 25, 2005 | 09:53 PM
Default 350x Axle
i tihnk the atc/trx will but i'm not a 100% but if u change the bearing carrier it will for sure
Old May 26, 2005 | 12:23 AM
thebutelr's Avatar
Default 350x Axle
Now another question, will a 250r or 250x bearing carrier work for a 350x? Cuz i'm probably gonna need to replace mine plus i'm tired of changin those stupid single row bearings all the time, i want somethin that'll last for a little while.
Old May 31, 2005 | 12:48 AM
thebutelr's Avatar
Default 350x Axle
Anybody know?
Old Jun 2, 2005 | 02:47 PM
Default 350x Axle
This is what I came up with....the 85 350X......only fits a 85 350X. BUT the 86 350X is the same part as all the Trx 250X and the trx 300Ex. I have no clue on what the difference is???????????? [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img] Look HERE
Old Jun 13, 2005 | 05:01 PM
VT250X's Avatar
Default 350x Axle
The stock bearing carrier from a 250X will fit the 350X swingarm. I know because I have done it. The 250R carrier WILL NOT. You can also use an axle from a 250X/300EX, but it will be about 1 1/4" narrower and you will have to use the hubs from the 250X. FYI the hubs from the TRX250R and the ATC350X are interchangable.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
