01 raptor clutch qestion
Old May 20, 2005 | 09:56 PM
RAPTORFAN85's Avatar
Default 01 raptor clutch qestion
on my 01 raptor i have just recently noticed what i believe to be the clutch slipping.
it happens the most if i'm doing wheelies in second or if at high speed like 4th if i let off then punch it. it seems to hesatate and then it will pick up. i have just recently had motor work done but by a dealer who said they stricktly use yamalube. also what reciept says. the adj. on the cable seems fine. i just recently added a dr.d slip on and jet kit which added considerable low to mid power. could it just be that the clutch was going and this pushed it to far? i mean this just seemed to happen quick and it slips pretty bad. if i should put on a new clutch what do people recomend. i figure i might do like a clutch basket as well while im in there right? any other recomends
thanks for the help
Old May 21, 2005 | 03:19 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Just get the GYTR clutch kit. If the basket isn't worn out no need to replace it. Do a search on raptor clutches you will see what I mean.
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
