Raptor jumps in first
Old May 21, 2005 | 01:46 PM
Raptor0502's Avatar
Default Raptor jumps in first
When my quad is cold i start it up and after about 3 or 4 minutes of letting it warm up i put it in first and it jumps and starts to move forward. I have already tried ajusting the clutch but it still does it. After i ride it a little it stops. Is this normal, or does my clutch need to be adjusted.
Old May 21, 2005 | 01:51 PM
AZDUNERAT's Avatar
This is a common and known problem from what I have read. I think there have been a couple of board members with the same issue. If it is still under warrranty Yamaha will replace the entire clutch. Otherwise I dont believe adjusting the clutch will fix it I believe it is a problem in the basket.
Aaron
Old May 22, 2005 | 01:30 PM
Z40005BR's Avatar
Well, first it sounds like your clutch is sticking. you can live with it but just make sure you take a stick and start it by using using it to press the start button. Because its a raptor...........not a white 2005 yoshimura Z400.
Old May 22, 2005 | 04:11 PM
Seibert51's Avatar
Its normal , mine did it too before i took it in for the 10 hr check up., pretty much its called a wet clutch, it means there is oil in there and before it gets warmed up it is really thick, then when ur motor is warm it becomes easier, when u take it in for the check up they should fix it were it doesnt do it though.
Old May 26, 2005 | 05:44 PM
Raptor0502's Avatar
z40005BR mabey you could explain the starting the quad thing with a stick to me again because i am not really getting whatever the he11 you are saying.
Old May 30, 2005 | 05:05 PM
Raptor0502's Avatar
Do you think that the problem could be my oil. I am currently running 10w-40 in it, should i use a lower oil grade
bmxatv10
Oct 14, 2022 06:23 PM
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
Hack714
Sep 20, 2015 05:54 PM
Alex Rodak
Sep 12, 2015 09:39 AM
