High compression pistons
Old May 23, 2005 | 11:56 AM
MadBaja819's Avatar
Default High compression pistons
Alright well I've been redoing the Baja for a month or so now gettin everything freshened up and rebuilt and I was thinking of installing a High Comp piston while I have the motor apart. I would like everyone's input on how to go with my given situation and riding styles: I ride mainly trails and race motocross on the weekeneds regularly. I have the mods listed in my signature and I would prefer to be able to still run 93 octane gas. I've been thinking 12.5:1, but I would like your input. Thanks alot [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 23, 2005 | 12:36 PM
saint650's Avatar
TO STAY WITH 93 OCTANE YOU WILL NEED TO STAY WITH 11.5:1 OR LOWER. ANY HIGHER COMPRESSION THAN THAT AND YOU WILL NEED RACE GAS
Old May 25, 2005 | 02:46 AM
ERBEDS650's Avatar
With the right cams, and 12 to 1 comp piston, you can run pump gas, give the guys a call at Web Cams a callText web cam
Old May 25, 2005 | 10:26 AM
SCOUNDREL's Avatar
I spoke to both Eric and Randall as well as Ron Woods and all three say NO to any compression above 11:5.1 if you want to use pump gas. You can but only under the circumstances that you go with a milder cam and then what's the point... [img]i/expressions/face-icon-small-confused.gif[/img]
Old May 25, 2005 | 11:49 AM
MadBaja819's Avatar
Thanks for the information, I will at the same time be going to a more aggressive cam also, so I suppose either I will stay at 11.5:1 or just go higher and bite the bullet and start paying for race gas.
Old May 25, 2005 | 12:00 PM
biggerisbetter's Avatar
Compression is not going to gain much HP, a good cam grind will do you much better.
If you want a good all around performing engine, then you want a Sportman cam from RWR, or a custom cam made from HPR, or Pami also has Sportman cams. The Web 110 is a good cam also. But you must decide WHAT you want out of your engine. If you want a drag racer, then their are also cams that will make your motor biuld more HP, but way up in your RPM range, so they suck for anything else but drag racing.
Cam choice is Critical.
Bigger.
Old May 25, 2005 | 02:13 PM
SCOUNDREL's Avatar
Ya what he said....
I went with the 12:1 and HR3 cams from MrHp. However I elected to build the gasket kit up to bring the compression down to around 11:1. I did this so if I decide later to increase the compression all I need to do is replace the gasket set.
Old May 25, 2005 | 03:11 PM
shmee's Avatar
iv seen the web 110's make very good power. but the bigger the cams i would go with more comp so you gain that lowend back.
Old May 26, 2005 | 10:13 AM
SANDMAN430's Avatar
do those extra gaskets do anything to the cam timing?
Old May 26, 2005 | 10:53 AM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Different gasket heights do effect cam timing. A major gasket difference will only change cam timing .25-.50 degrees. There is no way to detect this small of a change as far as hp goes.
