Raptor Sneezing..
Old May 26, 2005 | 11:33 PM
yamahaandchevysgeterdun's Avatar
Default Raptor Sneezing..
This may sound stupid but...when i am just idling around the yard in 1st gear i will be going a long runnin just find and it will "sneeze" then will be fine again...Is this mean it is possible to lean?
Old May 27, 2005 | 12:05 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
sneeze? kinda liek a backfire throghu the carb? well.. watch out.., it can pop off the carb boot.. or even crack it like mine..
Old May 27, 2005 | 10:17 AM
Ya somthing like that, what is the problem though...? To lean? Or...? Or is it just normal?
Old May 27, 2005 | 02:40 PM
warriorboy22's Avatar
same thing happened to me and my carb boot cracked
Old May 27, 2005 | 04:11 PM
What causes this though? Or will i just have to live with it and watch it...?
Old May 27, 2005 | 04:50 PM
MrDumass's Avatar
Super Quad Patrol
Athens Archery Field Staff
Best lunch hour ever!
No-one is answering your question as to what is causing this!! Have you tried any remedies for it?? Did it just all of a sudden start doing this, or did you just mess with anything?? Like mods or carb work? Just trying to help get to the bottom of this.[img]i/expressions/face-icon-small-smile.gif[/img] I know I had similar problems at 1/8-1/4 throttle on my BigBear, and I ended up adjusting the air/fuel screw to make it go away. This was after I put the pipe/filter and jet in.
Old May 27, 2005 | 04:54 PM
No mods...only thing is a smaller sprocket...Tonight im gona rip it apart and richen it up a little bit to see if that helps. Thing barely has 5 hours on it.
Old May 27, 2005 | 05:32 PM
quicksilver's Avatar
probably your fuel/air mixture. richen it up a tad and see what happens.
Old May 27, 2005 | 06:01 PM
Ozark38's Avatar
Mine done that when I got it. Thought I just needed to ride it or break it in and it would go away.........not! It had a very annoying hiccup when going slow about an 1/8 throttle. I put a Dynojet kit in and the problem went away. I would try go out a little more on your air/fuel screws.
Old May 29, 2005 | 05:31 PM
skii0's Avatar
air/fuel screws....[img]i/expressions/face-icon-small-happy.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
