Raptor Sneezing..
This may sound stupid but...when i am just idling around the yard in 1st gear i will be going a long runnin just find and it will "sneeze" then will be fine again...Is this mean it is possible to lean?
No-one is answering your question as to what is causing this!! Have you tried any remedies for it?? Did it just all of a sudden start doing this, or did you just mess with anything?? Like mods or carb work? Just trying to help get to the bottom of this.[img]i/expressions/face-icon-small-smile.gif[/img] I know I had similar problems at 1/8-1/4 throttle on my BigBear, and I ended up adjusting the air/fuel screw to make it go away. This was after I put the pipe/filter and jet in.
No mods...only thing is a smaller sprocket...Tonight im gona rip it apart and richen it up a little bit to see if that helps. Thing barely has 5 hours on it.
Mine done that when I got it. Thought I just needed to ride it or break it in and it would go away.........not! It had a very annoying hiccup when going slow about an 1/8 throttle. I put a Dynojet kit in and the problem went away. I would try go out a little more on your air/fuel screws.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
