Dynojet,, Is it worth it?
Old May 27, 2005 | 11:34 AM
GR8Outdoorsman's Avatar
Default Dynojet,, Is it worth it?
Just wondering if it is worth installing a dynojet on my Prairie 300? I already have the dynojet kit, but I am undecided on if I should install it or not. Just trying to help make up for some of the lost power due to the larger tires and lift kit.
Old May 28, 2005 | 02:16 PM
beerbq's Avatar
I have a lakota 300 and after I installed the dynojet kit, it made a big difference.
Old May 28, 2005 | 03:41 PM
Thank you for your advice,,,,,, it just looked to me like a lot of guys were having a difficult time getting the jet kit set up right and in the end they weren't getting that much of an increase....... Maybe I will go ahead and drop it in....
Old May 28, 2005 | 03:57 PM
mmmbeefy's Avatar
I can't speak for your utility machines, but I certainly noticed a difference on my Rappy. As long as you haven't made any major changes to your motor (beyond a pipe, airbox, etc) the recommended jets that the kit instructs you to use for your altitude, you should be in good shape.
Old May 28, 2005 | 04:23 PM
Where did you guys notice the greatest improvement???? In the top end, out of the hole, or just all around???
Old May 28, 2005 | 04:36 PM
mmmbeefy's Avatar
I notice the biggest difference as I was pull away from my friends! About mid-way down the track, so that's mid range right?!?[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 31, 2005 | 10:04 AM
beerbq's Avatar
Inoticed a lot faster throttle response and mid to top performance. You will have to do some drilling on your carb its scary but it worked.
Old May 31, 2005 | 06:44 PM
Drilling???? The manual that came with the kit didn't say anything about drilling.......interesting
Old Jun 1, 2005 | 01:19 AM
mmmbeefy's Avatar
?!? no drilling here amigo!?!
Old Jun 1, 2005 | 01:35 AM
ManicHaze's Avatar
depends on the application. Just do as the manual says.
