2005 TRX 250r
Old Jun 5, 2005 | 01:52 AM
RedNeckMXRider2's Avatar
Default 2005 TRX 250r
Wondering if any yall have seen it, its in the new atv sport mag look like its in a 400ex frame with aftermarket shocks and FMF pipe
Old Jun 5, 2005 | 03:32 AM
dragginwagon406's Avatar
http://www.servicehonda.com/service.html
2004 Service Honda TRX250R Exclusive Features
• Powerful and durable 250 cc 2-stroke engine is the most powerful engine fitted to any sport atv.
• Backwards kick starter for easy convenient starting.
• The ultra-lightweight TRX250R weighs only 310 pounds.
• Additional frame gusseting for durability in severe use.
• Fully customizable with a wide range of options, including swingarms, a-arms, and shocks tuned specifically for the Service Honda TRX250R prior to delivery.
Engine
• High performance liquid cooled two stroke single cylinder engine with 66.4 mm x 72.0 mm bore and stroke and 8.5:1 compression ratio.
• Six pedal reed valve improves throttle response and power delivery.
• CRV rotary/flap exhaust valve has longer extentions on the side of the flap to better follow the exhaust port shape for increased internal turbulence, improved exhaust scavenging, and responsive acceleration.
• Expansion chamber is nickel plated and tuned to meet atv requirements for torque and useable horsepower.
• 16-bit processor in the ignition CPU provides fast data calculation and accurate timing for the solid-state 3-D map style digital ignition.
• Lightweight 38 mm Flat slide Mikuni TMX carburetor adds both initial throttle crispness and excellent throttle response to compliment the engines abundant power.
• Custom aluminum radiator futures 35% more core area than the original TRX250R for significantly improved heat dispersion.
• New radiator directly interchanges with original TRX250R radiator allowing original TRX250R owner to upgrade and allowing easy field service-ability for the new TRX250R using existing spares.
• Steel water pump gear for excellent reliability in ATV service.
• Durable, smooth shifting close ratio five speed transmission.
• Primary kickstarting allows starting in any gear.
Chassis
• Rugged steel frame with removable sub frame for easy maintenance.
• Independent double wishbone front suspension.
• Pro-link rear suspension with fully adjustable large diameter aluminum body Showa shock absorber is standard.
• Beautiful one-piece cast aluminum swingarm offers exceptional rigidity.
• Radial tires for exceptional handling.
• Triple disc brakes provide superb stopping power.
• Aggressive body style compliments the all sport appearance.
• Lightweight aluminum wheels reduce unspring weight for better handling.
• Durable heavy duty o ring sealed drive chain.
appears to be legit at $9000 ...they also sell a cr500 dirt bike also
Old Jun 5, 2005 | 03:07 PM
DavidLT250S's Avatar
wow...are these only for sale in USA?
salixair
Nov 3, 2015 08:25 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Brandon400
Sep 5, 2015 08:44 PM
