Headlight/taillight fuse on KLT 250
Where the heck is the fuse for the lights on a Kawa KLT 250? I've either got a bad fuse or a bad switch, but I haven't been able to find the fuse, and I'm not in the mood to remove the rear bodywork unless I have to.
No fuse, sorry check for power to head light up right side of frame at the front using a test light, pull the 2 wires apart at the connection test for power, on both leads using the ground for the battery (switch on). If its dead your switch is dead. Switches are as easy to find as teeth on chickens. if its dead wire it open, put in an inline switch on the front frame for the headlight if you need stealth mode. Canada you have to run headlight tail light all the time anyway.
