Headlight/taillight fuse on KLT 250
No fuse, sorry check for power to head light up right side of frame at the front using a test light, pull the 2 wires apart at the connection test for power, on both leads using the ground for the battery (switch on). If its dead your switch is dead. Switches are as easy to find as teeth on chickens. if its dead wire it open, put in an inline switch on the front frame for the headlight if you need stealth mode. Canada you have to run headlight tail light all the time anyway.
