DS spitting and sputtering
Old Jun 7, 2005 | 10:14 AM
2BIG2BFAST's Avatar
Default DS spitting and sputtering
My ds has been sitting for about 3 months, I charged the battery and when it finaly started all it would do is sputter and backfire. I cant get it to rev up at all. How long does it need to sit there idaling before it uses the bad gas inside the carb? Now i know why they say when not in use turn the gas off.
Old Jun 7, 2005 | 11:22 AM
Oldmanracing's Avatar
Your pilot circuit appears to be gummed up.
Screw out and remove the pilot adjustment screw.
Start the motor and try to rev.
What ever the highest rpm you can get, then cover with finger the pilot screw hole.
Sometimes you get lucky and suck the tarnish through.
Replace pilot screw and set 3 turns out. Start motor.
If still running poorly. Remove carb, spray passages with carb cleaner and blowout with compressed air.
Old Jun 7, 2005 | 06:22 PM
biggerisbetter's Avatar
If carb is checked out, it could lso be the rectifier. you can turn the head lights on, and if it runns fine then change your rectifier.
hopefully its your pilot jet[img]i/expressions/face-icon-small-smile.gif[/img]
bigger.
Old Jun 7, 2005 | 08:44 PM
2BIG2BFAST's Avatar
I let the battery charge all day at a 2 amp charge. when i got home if fired right up no missing or sputtering. If the battery doesnt have a good charge can it affect it like it did this morning? I tried 4 or 5 times since i got home and no more problems.
Old Jun 8, 2005 | 02:48 PM
RallyRider05's Avatar
mabby its just one of thoughs things that fixes itself[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 10, 2005 | 08:43 PM
mean650's Avatar
2big,
yes ,
if the battery is weak it will run like crap.
ReconBayou
Oct 31, 2022 05:37 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
alzgarvin
Sep 11, 2015 08:53 AM
Slagpolaris
Sep 5, 2015 09:41 PM
