Raptor 350 Front Sprocket
Old Jun 8, 2005 | 07:33 PM
420rappy's Avatar
Default Raptor 350 Front Sprocket
Hey just wondering how hard is it to put in a 12 t front sprocket on a raptor 350 and would it lose much top end?
Old Jun 8, 2005 | 08:30 PM
clover's Avatar
It isn't hard at all to put a front sprocket.You'll lose around 3-4 mph on top end.
Old Jun 8, 2005 | 09:20 PM
420rappy's Avatar
what size is that nut ?
Old Jun 8, 2005 | 09:34 PM
yamaharaptor350's Avatar
Yea u loose a couple on top end but overall it will get ya where ya want alot quicker in the trails and gives much better bottom end. If u have 22's in the back i highly sugest the 12 tooth... thats what im runnin right now and it rips in the trails and is better all round even on the straight it feels quicker but i got through gears quicker on the straights. I always stay in like 2nd and 3rd now in the trails insetead of the first 3 gears... i occasioally have to go down to first but not often and not for long.
Old Jun 8, 2005 | 09:47 PM
420rappy's Avatar
i just have the stock size tires in the rear what would be the best sprocket size for that?
Old Jun 8, 2005 | 09:51 PM
id still get the 12 it will really help the low end... im gona go back down to 20's in the back also soon and run the 12... u wil see the improvement and even if ya dont like it u can just switch back to the 13, its not hard to change a front sprocket and its also very cheap it will cost ya like 15 bucks.
Old Jun 9, 2005 | 01:16 AM
2FAST4URASS's Avatar
AS they allready said it easy as it can be first step go to the back lossen ur chain adjuster lossen the two bolts as you would if you were to tighten ur chain go to the front take the plastic cover off there a little thin washer with ears bent over the net to keep it tight while rideing get a flat head screw driver bend it up and chances are you will not have a socket that big to loosen the nut get some vise grips clamp down tightly and twist her off mine wasnt that tight so mayber ur want beok slide off the sproket with chain on it it will slide over just enuff to slide the sproket out put ur chain around the new sproket and slide it up on the spline and put ur nut back on tighten down bend the ears down around the net again put ur cover on go to the back tighten ur chain down again tighten the other two bolts and ride it and feel the great bottom end gain its soooo worth it .
Old Jun 9, 2005 | 05:18 PM
420rappy's Avatar
cool thanks for the info guys [img]i/expressions/face-icon-small-happy.gif[/img]
joeyupton
Jul 14, 2015 11:51 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
