RAPTOR rear breaks?
Old Jun 9, 2005 | 12:05 AM
660rapta's Avatar
Default RAPTOR rear breaks?
my raptor is almost brand new(2 weeks). when the quad is moving and i am NOT touching the break lever, the rear breaks are very slightly grinding, but enough to hear. its not a rough grind by any means. i sprayed it down with break cleaner and it still didnt stop. is this normal, does it take a while for the breaks to get broken in?
Old Jun 9, 2005 | 12:33 AM
pyro686's Avatar
CHECK YOUR EMERGENCY BRAKE
Old Jun 9, 2005 | 12:34 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
the old e-brake drag
it will get better as your pads wear in/out
the e-brakes are notorious for wearing out pads and needing constant adjustment to remain working
best bet is to remove the e-brake system
honestly,,,they are garbage
Old Jun 9, 2005 | 01:13 AM
Dwags's Avatar
agreed take the e-brake out!! the elctronic switch will give you trouble to
Old Jun 9, 2005 | 01:24 AM
660rapta's Avatar
how do i adjust my ebrake. did you take the ebrake off your raptor, thanx for responding
Old Jun 9, 2005 | 01:28 AM
Bing's Avatar
Super Quad Patrol
i have taken the e-brake off every sport quad i've ever owned,,,,especially yamahas
to adjust:
on the left side of the rear caliper there is a bolt sticking out with a locknut
loosen the nut,,,,and move the bolt in or out as needed
if you keep it in adjustment....you may as well order some brake pads now,,,so you have em on hand[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 9, 2005 | 09:27 PM
CTracingraptor's Avatar
you could have bend your rotor on a raock or something, is it a constant grinding our a small repitition of grinding sounds
Old Jun 10, 2005 | 02:51 AM
660rapta's Avatar
its constant so i dont think its bent, i adjusted my ebrake and its still making the noise but it doesnt affect its movement so im not to conserned.
Old Jun 10, 2005 | 03:24 AM
spudley's Avatar
I had the same problem and found if you adjusted the cable and it is still doing it back that bolt off that goes into the brake caliper not to much and then tighten the locknut, the caliper is fairly sensative to over tightening.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
Asaran
Oct 8, 2015 11:14 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
