Raptor 660 question
Old Jun 9, 2005 | 06:58 PM
MichaelV's Avatar
Default Raptor 660 question
On my raptor 660, I can't get the backend to slide around fast corners, it keeps wanting to wheelie and flip over on its side. It has the stock rear axle. Is there anything i can do to fix this prob.
Also when i do a wheelie and ride it for a long time the motor seems to wanna cutout and die, i guess cause it runs the gas out of the overflow tube. Has anyone else experienced this problem. Is this fixable.
thanks
Mike
Old Jun 9, 2005 | 07:24 PM
inferno's Avatar
check your air pressure in you tires i run 4 with a low pressure gauge and i can slide it perfect
and it cuts out becase its not getting enogh gas it is going out the overflow like you said
Old Jun 9, 2005 | 07:37 PM
midnite's Avatar
The lower the air pressure you run, the more traction you get. So to get your tires to slide better, run the maximum pressure. When your tires wear out get razors, the will slide better than the stock radials. The tippyness is a raptor trait. I've heard of good things from making the raptor wider +4, and longer +4.
Old Jun 9, 2005 | 07:55 PM
MichaelV's Avatar
Hey inferno,
how much pressure do you run in your tires, front and back? also can i just plug off my overflow tube to keep the it from dying when i wheelie?
thanks
Mike
Old Jun 9, 2005 | 08:09 PM
inferno's Avatar
i run 4 in the front and rear make sure you use a low pressure air gauage
Old Jun 9, 2005 | 08:19 PM
MichaelV's Avatar
hey inferno, what about the gas running out the overflow. Can i just plug it off or run the line up higher?
thanks
MIke
Old Jun 9, 2005 | 08:22 PM
86LT250RFatty's Avatar
run it up higher i dont think it will work if you plug it it wont flow
Old Jun 9, 2005 | 08:23 PM
inferno's Avatar
yea i bet you could plug the line or run it up higher i wouldnt plugg it because then i might not let you get enough air
Old Jun 9, 2005 | 08:25 PM
MichaelV's Avatar
Yea the thing will only wheelie about 75 feet and then cutout. Has anyone else had this problem.
thanks
Mike
Old Jun 9, 2005 | 08:28 PM
HughJazz's Avatar
Check and make sure you float levels are set right
