Raptor 660 question
Originally posted by: HughJazz
Check and make sure you float levels are set right
I can wheelie my Raptor all day with out it cutting out or spilling fuel out the over flow tubes. I would check the floats. As far as it being tippy I dont even notice it any more, use your body in the corners to keep it from 2 wheeling and stay on the gas.
#15
I raised the two rubber lines that are coming out of the very bottom of the carbs. I guess these are the overflow tubes, right or not? It still cuts out after i ride a wheelie for a while and then really open the throttle up. What are the floats supposed to be set at.
Thanks
mike
Thanks
mike
Aug 21, 2015 01:23 PM
