05 scrambler in H2O???
Old Jun 12, 2005 | 12:47 AM
captainextreme's Avatar
Default 05 scrambler in H2O???
hi there just picked up an 05 scambler, i noticed the clutchs easially get wet, and begin slipping. is there any cure or trick to kepping them dry? figure that someone has to have some kind of backyard fix for this!!
thanx
captain eXtreme
Old Jun 12, 2005 | 12:50 AM
XtremeSkier's Avatar
i know a trick
dont drive through deep water[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jun 12, 2005 | 12:57 AM
SPORTSMAN70003's Avatar
thanx
captain eXtreme
Sounds like you have a clutch cover seal bad or a hole in your cover. It could also be from a warped clutch cover that has gotten to hot and is not sealing.
Old Jun 12, 2005 | 01:01 AM
TrailBlazerguy250's Avatar
take the belt cover off and put a little line of silicon on the seal and put it back on , worked great on my SP
Old Jun 12, 2005 | 01:10 AM
TehWarriorGuy's Avatar
Originally posted by: XtremeSkier
i know a trick
ha thats what i'd say
Old Jun 13, 2005 | 09:36 PM
Ridinghard's Avatar
I have the 05 and have run it many times in water up to the seat. The only time I had a problem was not even due to the clutch slipping, it died while submerged, but after draining the water out and regreasing everything it goes great. I bet your clutch cover was not put on right. I'd buy a new seal and put it on carefully.
Old Jun 14, 2005 | 12:03 AM
scramblerXrated's Avatar
i have also heard of people taking an OUTERWEARS air filter cover, and cutting it to fit around the clutch housing snorkel opening. since these snorkel openings are particularly low on the scramblers, it wouldnt prevent water totally, but it would help to keep the water from rushing in during a deep water crossing. thus, keeping the clutches dryer for just a bit longer.
if it helps to keep water outta the motor, it oughta do the same fer the clutches.
i havent actually tried this, but the theory seems sound. most outerwears are only $10 anyways. so it seems like its worth a shot.
just some ideas......
X
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
