Raptor 80 starts on push but not with starter
Old Jun 12, 2005 | 08:48 PM
robengineer's Avatar
Default Raptor 80 starts on push but not with starter
I have a 2002 yamaha raptor 80. Recently it has developed a starting problem. If the quad is not warmed up and I try to start it with the starter it will crank & crank but does not fire at all. If I put it into second gear and push it about 10ft it will start right up and idle perfectly. Once it warms up, the starter will start the quad perfectly as soon as I hit the button. If I then let it sit for several hours, then same problem happens again where I have to puch it to start it. I have changed the spark plug, installed a new battery, completely flushed the gas & carb with no improvement. I also checked that the spark plug had spark when cranking the starter. Any idea what could be going on here?
Thanks,
Rob
Old Jun 12, 2005 | 09:57 PM
86LT250RFatty's Avatar
i dunno, but how the hell are you bump starting an auto-clutch?!?!? goin into nutreal and then goin into 2ed? wouldent it just roll?
Old Jun 13, 2005 | 12:33 AM
I just put it in 2nd gear and push it. The raptor has no manual clutch, but three manual gears. I only have to push it about 10ft and it starts right up.
Old Jun 18, 2005 | 03:21 AM
XR650Warrior's Avatar
A common re-occuring problem, a valve adjustment will take care of it.
Shawn_z400
Jul 1, 2015 03:37 PM
jayking232003
Jun 9, 2015 02:54 PM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
