spark arrestor, too soon to take out?
Old Jun 12, 2005 | 09:35 PM
660rapta's Avatar
Default spark arrestor, too soon to take out?
my raptor has about 5 hours on it, i want to know if i should wait longer to take the spark arrestor out or will it be ok to remove it now, will taking it out screw up my break-in. also if i take it out am i going to lean out my motor enough that i have to rejet? thanx
also there is a squeeking coming from my rear shock linkage. any suggestions?
-sam
Old Jun 12, 2005 | 10:51 PM
Fastblasterboy's Avatar
I dont think it would hurt but u should get some better advise than me
Old Jun 13, 2005 | 12:32 AM
660rapta's Avatar
please reply more i need to know about the spark arrestor in my raptor!!
Old Jun 13, 2005 | 01:40 AM
YamahaRyder4Lyfe's Avatar
I took mine out after about 10 hours...and it works the same, and the plug is tan on mine, so i didn't have to rejet. If you take it out, sometimes there a b*tch to get back in. I took mine out to hear how it sounds, i liked the sound and the spark arrester was bent to hell and back, so i just didn't put it back in. and just to let you know, its pretty loud without it. if you decide to take it out...let me know, ill tell you how i did it (it can be hard sometimes)
Old Jun 13, 2005 | 01:58 AM
Ricke's Avatar
yea how do you get it out? do you have to just take that screw out and put the metal peice out or what?
Old Jun 13, 2005 | 02:33 AM
660rapta's Avatar
its simple, i have done it before, the reason why it was easy for me is becuase i took it out and put it back in when there was hardly any carbon build up. thanx for your input, i think im goin to ride for a couple more hours before i do so.
Old Jun 13, 2005 | 11:53 PM
Yeah, take the screw out, and just get some good vice grips and pull it out. Usually, its stuck in there reeaal good. I had to get a torch (cutting torches) and heat the metel around it till it got red hot. Then it came out barely.
Old Jun 14, 2005 | 12:11 AM
rynokron's Avatar
i removed mine after the first ride. it came out fairly easy account it was new. it 's a fair amount louder. if you have any backfires or lean spots, open your fuel screw a little.
Old Jun 14, 2005 | 12:26 AM
Ricke's Avatar
i tryed and tryed to pull it out i just cant get it out
Old Jun 14, 2005 | 12:32 AM
rynokron's Avatar
i grabbed mine with some vise grips. with some twisting and pulling it came out. try a little wd-40 to loosen it up.
