Broken bolt..lower right rear A arm
Old Jun 13, 2005 | 09:39 AM
shaq700's Avatar
Default Broken bolt..lower right rear A arm
Has anyone else experienced this? The bolt broke cleanly off leaving the threaded end still in through the bushing.I can foresee a nightmare getting this out!
Old Jun 13, 2005 | 05:58 PM
GITRDONE's Avatar
I have broke 4 bolts on my 2002.
Take the tire off, Remove the lower arm bolts,drill a pilot hole into the broken bolt & then us a EASYOUT. The bolt should back right out.
(Mine did anyway).
Here is the fix. Mine was a 3/8 " bolt, go get some grade 8 bolts & replace all of them at once. Use some blue Loctite thread locker on the threads, assemble, tighten up & then regrease the bushings.
I did this about 700 miles ago & i haven't had a problem since.
If it happens again I will use a allen head cap screw, these are Grade 12. (Real Hard Steel).
Old Jun 13, 2005 | 07:40 PM
Oleman's Avatar
I understand it's not that uncommon. Grade 8 fasteners are the recommended fix. The bolts on your 700 should be 7/16"-14 x 2.75". I think Gitrdone is referring to Loctite 242 threadlocking compound. The compound is blue, not the packaging.
Old Jun 14, 2005 | 09:42 AM
shaq700's Avatar
Thanks guys, I got that out last night by welding a nut on the broken bolt.....no problems with that.The problem lies with getting that size bolt in a higher grade and in 2 3/4". I'm definitely not using a gr.5.
greg74
Sep 10, 2019 03:03 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
mrmickman123
Aug 30, 2015 10:37 PM
DFWSRT8
Aug 20, 2015 09:24 AM
