400 Scrambler Problems
Old Oct 10, 2000 | 11:02 AM
rkp's Avatar
rkp
Need help w/ 98 400 Scrambler. Starts good, no power, no top end, runs a little rough. Went through carb, everything looked O.K. Could it be an electrical problem, or reeds, or exhaust? Problem started all of a sudden after being used to just putt around a creek for a couple of hours. Spark plug looks fine. Any help would be greatly appreciated. Thanks.
Old Oct 10, 2000 | 06:35 PM
QuadBuster's Avatar
Is your engine winding up o.k. but not delivering the goods?
Check the clutch belt?????????
EC
Old Oct 15, 2000 | 02:58 PM
Farmr123's Avatar
Check for intake or exhaust restrictions first.
Old Oct 17, 2000 | 04:16 PM
rkp's Avatar
rkp
I took the exhaust off and everything looked fine. Couldn't tell if there were any ristrictions in the muffler. Took the carb off and looked at it, everything seemed fine as well as the air filter. Runs ok until you try to go past half throttle. Then it just kind of sputters and bogs down like you have the choke on. I don't know what to think. Is there any type of electrical timing advance or anything like that?
Thanks
Old Oct 17, 2000 | 06:27 PM
QuadBuster's Avatar
Is the bike stock?
What jetting are you running?
Are you sure its running strong until 1/2 throttle?
EC
Old Oct 17, 2000 | 09:07 PM
scramblered's Avatar
hi man!i kwnown what you talked about man,it's a fuse right in front your scrambler bottom your handle bar where the fuse and electrical stuff are located,just read the electrical shema of you owner guide scrambler and just by disconnecting a thread it will be right.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
