kodiak hesitation
Old Jun 16, 2005 | 03:13 PM
kodiakman5's Avatar
Default kodiak hesitation
I'm asking for help. I have always had a slight hesitation in my 2004 450 kodiak. this happens when you first give it gas there is like a dead spot then it takes off. or it wants to cut out on you when for give it gas or take off and when it is in 4wd. well yesterday a went on a ride where I had to cross a creek a few times now this creek is not super deep and I crossed it some last year with no problem, but yesterday it would want to stall out even if there was a small almount of water in the road. if I went in it, it wanted to stall out. I would have to keep the throttle wide open when i crossed the creek or hit a water spot in the road. this is a stock bike all but the 26 inch mud lites and ITP wheels. it is starting to do this more now and I would like to know if anyone has any idea what is going on. thanks.
Old Jun 16, 2005 | 04:11 PM
tecc77's Avatar
First do the dummy checks.......
1. Does it have air/ air filter clean and properly in place.
2. Gas, does it have water in the gas?
3. Does it smoke ?
4. Does it have good spark...............................
Pull your plug and tell us what color it is. That way we can tell if your lean or rich. I would assume your too rich. I need more info though.
Old Jun 16, 2005 | 04:29 PM
UltimateAussie's Avatar
sounds like your belts slipping
Old Jun 16, 2005 | 04:52 PM
CobraR6's Avatar
I have the similar problem with my 04 Bruin 350 4x4. When its sitting still, when I give it gas, there is a hesitation, only for a brief second or so but still a hesitation before it goes. Any ideas on how to fix it.
Old Jun 16, 2005 | 05:01 PM
tecc77's Avatar
Its kinda hard to mistake the sound of a belt slipping.
Old Jun 16, 2005 | 08:41 PM
AlaskaBoy's Avatar
kodiakman,
Another stupid one to check, by any chance is your choke lever all the way closed? Mine has done this on occasion but it was because I bumped the choke lever and it does not take much for it to run rich this way and want to die.
AlaskaBoy.
Old Jun 16, 2005 | 11:58 PM
vmaxer's Avatar
Some times just by turning the fuel mixture screw out 1 turn farther can really improve low end response and idling, 3to 3.5 turns out from fully seated position seems to work nice..
Old Jun 17, 2005 | 12:18 AM
kodiakman5's Avatar
how do you know which jet controls what. is there a site that shows service books for atvs
Old Jun 17, 2005 | 07:51 AM
vmaxer's Avatar
The fuel mixture screw is located on the bottom side of carb in front of float bowl, you cant see it ,it is inside a round piece of casting that comes down from carb, ,there is a special tool to get in there, but if you loosen carb and rotate it aliittle you can get a flatblade screw driver in to adjust it.
hueby
Nov 6, 2015 11:34 AM
YankeeRebel
Oct 6, 2015 06:44 AM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
D-Hagz
Jul 4, 2015 02:19 AM
