05' 700/800 Overheating Anyone??
Old Jun 16, 2005 | 05:23 PM
tbg120's Avatar
Default 05' 700/800 Overheating Anyone??
Just wondering if anyone has had an overheating issue with their 2005 Sportsman 700 or 800. I am having an overheating problem with mine specifically when the radiater gets a little dirty. Not dirty to the point where half of it is plugged but just from normal trail riding.
I have made all of the basic checks, coolant level, fan operation etc.... If you did have a problem I would be interested in knowing how you solved it.
Old Jun 16, 2005 | 06:29 PM
2c3's Avatar
2c3
take the radiator screen protector off and make sure its not clodded with mud. you can also spray it from the top side inside the front cargo box. if none of that works you have a water pump problem or maybe your thermostat is sticking. i took mine to a mud bog 2 months ago and had that old thick sticky mud all up in my radiator and it never once run hot. good luck.
Old Sep 25, 2005 | 08:19 PM
elkbow's Avatar
mine is in the shop, i am getting error 51 which relates to number 1 fuel injector, but the dealer said multiple things will point to error 51, he said the biggest issue that he was having was the thermostat going bad, had to replace a few of them....i have the efi model....
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
