97 Scrambler, Bad Throttle Safety Switch,,,HELP!!!
Old Jun 16, 2005 | 10:27 PM
mrtool2u's Avatar
Default 97 Scrambler, Bad Throttle Safety Switch,,,HELP!!!
A buddy of mine just picked up a 97 Scrambler,,,well,he dang near stole it,,,,600 bucks... When he got it, it would not idle once you got it started,,they cleaned the carb,but to no avail,,, I thought right away it acted like the throttle safety switch. Well the switch was bad,,the microswitch was always in the closed position,,no matter where the lever was on the switch. We cut one of the wires,and wammo,,it will now idle decent. The only problem is,,it does not seem to run as well as it should,,sort of boggy,,will not pull wheels even.
The carb is spotless,,I checked it,,,compression is great,,,choke is adjusted,etc. My question is,,will this switch being disconnected(one wire cut) affect the mid and top end performance. The Poo dealer wants 130 bucks for a new one,,he would like to go without it. Any info much appreciated.
Old Jun 17, 2005 | 12:02 AM
mrtool2u's Avatar
Bump
Old Jun 17, 2005 | 07:49 PM
ftwflh's Avatar
Follow the wires from the switch to the wire block and unplug them and see if that helps.
skinnyr6
Aug 25, 2023 02:18 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
