Warrior Won't start
Old Jun 17, 2005 | 09:50 AM
Dement's Avatar
Default Warrior Won't start
Okay heres the deal. My warrior acts as if the battery is not connected. No lights, no neutrel light. But it will start if I run cables from the battery to the starter. I have wd-40'ed all the connections and also checked for loose connections. Any help would be appreciated. Thank you.
Old Jun 17, 2005 | 10:10 AM
warriorboy22's Avatar
there probably is a loose connection somewere but thats going to be a pain to fined
Old Jun 17, 2005 | 10:21 AM
Dement's Avatar
Can that little brass thing near the back on the left side go bad? Or what about the run switch. I took that apart and cleaned it.
Old Jun 17, 2005 | 10:34 AM
UltimateAussie's Avatar
thats the starter soliniod i think . it may be your problem are the connections on your battery tight
Old Jun 17, 2005 | 10:39 AM
Dement's Avatar
Yep the cables are tight everywhere I can see. Fuse is good. I can seem to understand what else it could be. I mean theres not much wiring to these things. I have also taken cable and touched the postive and negative on that starter solinoid and the ATV trys to start. so it's making me think its not the run switch.
Old Jun 17, 2005 | 10:44 AM
there is a ground on the left side of the engine where the chain is. you just take off the chain guard thing and there should be a reverse sensor and a black wire bolted to the frame. if it somehow became loose it could cuase all that to happen
Old Jun 17, 2005 | 10:46 AM
2phast4u's Avatar
when u hit the switch does the starter solinod(lil brass thing) make a ticking noise if so replace that and charge your battery and u will b set to go
Old Jun 17, 2005 | 10:52 AM
Dement's Avatar
No noise at all when I hit the start switch, NO lights. Its like the battery isn't even hooked up.
Old Jun 17, 2005 | 11:16 AM
2phast4u's Avatar
just replace the soliniod
Old Jun 17, 2005 | 11:19 AM
ss97's Avatar
Lets Ride!
Make sure the battery terminals are clean and tight and well connected....simple but often overlooked.
