300ex handlebar cover...
Old Jun 17, 2005 | 05:57 PM
RRP's Avatar
RRP
Default 300ex handlebar cover...
Has anyone eliminated this cover?what did you do for the ignition switch?I personally don't like the looks of it.The only problem with just taking it off is the fact that it screws the headlight plastic cover and leaves a gross looking void between the bars and the headlight itself.I have seen mini dashes for sale that keep the switch in place but they don't seem to make them for the 300ex.
Old Jun 17, 2005 | 06:06 PM
ridinsmooth's Avatar
i have seen people do and they mounted the ignition switch on the top side of the gas tank and also on the handle bars you will have to custom make you mount.
Old Jun 17, 2005 | 06:13 PM
RRP's Avatar
RRP
thanks.I was trying to figure out how to remount it to the handle bars.Never thought of mounting it to the tank plastic or may the side of thr fender just under the handlebars like the warrior.Now all I need it something to cover up the headlight mount.
Old Jun 17, 2005 | 07:46 PM
TossinMidgets's Avatar
i actually did myn last night. I put the key on the side like mentioned abouve and the rev. and neut. light on either side of the gas cap.
here is a link to a pic of a ex with side mounted key http://www.exriders.com/vbb/showthre...5&pagenumber=6
(youll have to scroll down a bit)
Old Jun 18, 2005 | 01:13 AM
TractorPacker's Avatar
Do you have a balloon?
Get some new bars, with a cross bar and pad. Once that is done you won't see that ugly gap. I used a one inch drill bit to mount the key in the cowling around the tank.
Old Jun 18, 2005 | 01:34 AM
exbob88's Avatar
Yeah well see what i did was took a dremial and i cut a square around the ignition and the bolts so it's kind of of a square around itso evey thing eles is gone hard to explan but hopefuly it helps
Old Nov 6, 2005 | 01:10 PM
beniful's Avatar
what i did was just cut around it. here are some pics if u wanna check it out, go here http://www.freewebs.com/angeldude52583/myquad.htm
taylor
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
