manifold to pipe seal?
Old Jun 18, 2005 | 06:53 PM
ChuckTB400's Avatar
Default manifold to pipe seal?
Ok i just got a pipe kit for my 400 trailblazer. It says in the instructions to use some kind of sealer on the manifold to pipe connection. The manifold has 2 rings that compress and go into the pipe. What is used as a sealer?
Thanks Chuck
Old Jun 18, 2005 | 06:57 PM
holeshotz8436's Avatar
put some non-silicone gasket sealer on both sides of the crunch gasket
Old Jun 18, 2005 | 07:23 PM
ChuckTB400's Avatar
Is there a brand that works best? Also i got the trail pipe and it came with a orange spring. I was reading and alot of places say that the orange spring is for race pipes not trail pipes. Is this true? thanks.
Old Jun 19, 2005 | 11:44 AM
any brand will do fine.......i cant help you with the spring thou
Old Jun 19, 2005 | 10:06 PM
ScramaDamaDingDong's Avatar
what brand pipe kit did you get? if you bought it as a kit then i'm sure they are matched
Old Jun 20, 2005 | 01:01 AM
ChuckTB400's Avatar
The pipe kit is a rcr trail kit. on the site it says that you need the stock or green spring. It also says that the orange spring is for the race pipe. Ill call rick tommrow to find out.
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
Ahtatu
Sep 28, 2015 12:14 PM
