jetting question '00 Lakota
Old Jun 19, 2005 | 09:17 AM
Brianmud's Avatar
Default jetting question '00 Lakota
I was putting the IDS2 together & noticed in the instructions it says 'for stock jetting, 6 to 8 discs are ideal. The core itself does provide some back pressure that can't be eliminated simply by adding discs. For this reason, 10 to 12 discs is the practical maximum."
Are they referring, still, to the factory jetting when they recommend the 10 to 12? ST also says that adding more discs will make it run leaner, which is what I don't want- I'm jetting my main to a 134, & setting the new needle on #3 as per jet instructions, & adding a K&N filter kit. I'm below 5000ft(Baltimore), does the 134 w/ say 10-12 discs along w/ the K&N sound about right? Any of you out there installed a Supertrapp w/ a rejet & K&N?
Old Jun 19, 2005 | 11:35 PM
rolsmojave3's Avatar
if you go 10-12 discs and a k&N i'd go to a 136 or 138 maybe...do a plug chop to check the jetting out and go from there
Old Jun 20, 2005 | 05:52 PM
Brianmud's Avatar
Thanks for the tip RM3- I'm doing the whole thing thursday or friday, I say to myself, "Good luck".
Old Jun 30, 2005 | 05:52 PM
NEWDUCK's Avatar
If you have the race core would you like to trade for the quite core?
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
