Kazuma 50cc wont start
Old Jun 20, 2005 | 12:14 AM
QUADROOKIE's Avatar
Default Kazuma 50cc wont start
This thing has about one hour of ride time on 5 rides. It ran fine the last time it was rode. Sat for about a week, and now it will fire right up but die right away. Then wont even fire unless you let it sit for about 5 minutes. Then it will fire right up again but die immediately. Choke has no affect on it. Any suggestions? Thanks!!!
Old Jun 20, 2005 | 08:27 AM
tobybucksnort's Avatar
Have you adjusted the screw on the carberator?.When I received my sons we had to adjust screw(opposite side of choke lever)start by turning screw all the way closed(clockwise)then back out two complete turns and adjust so idle is correct(does not stall when throttle is depresed quickly)also check that hose from top of gas tank not pinched anywhere which can cause vapor lock.If this does not work,e-mail the folks at www.racewayatv.com they will answer questions even if you didnt purchase from them...good luck
Old Jun 20, 2005 | 08:34 AM
QUADROOKIE's Avatar
I'll check those things, thanks!
Old Jun 21, 2005 | 11:43 AM
quadrookie,I am interested as to what you found out,please repost if you get the problem taken care of...thanks
Old Jun 22, 2005 | 09:33 PM
QUADROOKIE's Avatar
Havent had a chance to check it out yet, I will post results.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 27, 2015 03:31 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
dcoleman
Oct 5, 1999 01:34 AM
