Air/Fuel Mixture Screw!
Originally posted by: RadRaptor
Where exactly is it located on the Raptor? I need to richen it a lil bit. There is one on each carb. i'm assuming so would i have to richen each one the same amount? Thx.
you will need to buy a special tool,,,or remove your carbs to adjust them (they are a pain)
for fine adjustments,,,you can turn one
for major adjustments,,both
I knew they were under there somewhere lol. Special tool? I knew they'e be a pain but didn't think i'd have to take the carbs off. I just need to richen up a lil bit. When I let off the gas got some mild backfiring. Matter which one I tune then? Thx. bud.
They do have to be turned the same amount of times and if your running a little lean you would turn them out. This is a pain in the @ss. I was not aware that there was a special tool, maybe I can fire the neighbors 12 year old.[img]i/expressions/face-icon-small-happy.gif[/img]
would there be the some screw and would it be the same process on a 05 400 kodiak, it is running to rich.
Oct 10, 2015 10:20 AM
