Squalling Starter on 400ex
Old Oct 11, 2000 | 12:46 PM
pudjumper's Avatar
This past Saturday night it got very cold at the Big River Sanddrags (29 F). Between races my engine cooled off to the point where I had to choke it, and when I was starting it the starter let out a squalling noise. After it warmed up the squall perished. Today the thermo hit 74 and no starter squall. Has anyone experienced this noise?
Old Oct 11, 2000 | 05:33 PM
Stallion19's Avatar
I have never taken mine to that temp. THe coldest that mine has seen is 50deg. and it just took a little bit more throttle pump to get it ove rand I let it warm up longer than normal and it ran fine. As long as it left after awhile and doesn`t do it on a regular basis then you dont have anything to worry about.
Old Oct 11, 2000 | 08:27 PM
Skunky's Avatar
More than likly your oil was not the right kind for that temp... The starter and ignition assembly all work with a splash effect to lubricate all the parts.. My guess would be that your oil was gooey.. froze alittle
Old Oct 11, 2000 | 09:10 PM
pudjumper's Avatar
You are probably right for I run 20-50 non synthetic oil. Never had any problems with any of my other bikes in the winter running 20-50. I'll try a 10-40 maybe 10-30 to see if that helps. Thanks
Old Oct 12, 2000 | 01:26 PM
86atc250r's Avatar
It's not an engine oil issue (although that is a little too heavy a weight for low temperatures & being a non-synthetic) . It's a starter bushing issue. Mine has made that noise at higher temperatures as well, first time I heard it was an evening in July.
Disassemble and lubricate.
Old Oct 22, 2000 | 06:04 PM
jonney's Avatar
Starters don't run in oil.
Old Oct 23, 2000 | 12:33 AM
rennym's Avatar
You are absolutely right! They don't run in oil!
My starter went on the fritz. I thought I burnt a spot in the brushes.
When we pulled it off, the starter was FULL of oil. I couldn't believe it.
Checked the fiche, no parts missing, cleaned it up and put it back together.
And I am extremely carefull to fill the machine properly when changing the oil....
Really wierd,
RM
Old Oct 23, 2000 | 01:13 AM
Skunky's Avatar
the fly wheel section of the 400EX has oil oil is splashed up to the starter through the gears.. If you pull your fly wheel cover you will find oil comes out
Old Oct 24, 2000 | 10:37 PM
jonney's Avatar
Have you seen one out ?some other brands don't use that theroy ,I haven't had any problems yet.
Old Oct 25, 2000 | 01:11 AM
Skunky's Avatar
ummm..yes.. many times...In my mods you will notice that i have a flywheel ignition key... if you pull the 4-8mm bolts of the starter cover and put your finger in there or just pull the gear out it will have an oil film over it..
akguy31
Aug 31, 2019 04:34 AM
flyin-lowe
Dec 1, 2017 03:18 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
