honda 200s clutch slipping
Old Jun 22, 2005 | 12:10 AM
maddmudder13's Avatar
Default honda 200s clutch slipping
hey when i ride my atc 200s and accelerate fast and when i shift gears i can hardly tell that it shifts because the engine doesent hardly bog down at all. do you think my clutch plates are shot? or the wrong oil? im running mobil 10w40. thanks jeff
Old Jun 24, 2005 | 01:44 PM
ThrashAndCrash's Avatar
have you adjusted the clutch yet?
Old Jun 24, 2005 | 02:19 PM
yeah.. turn the adjuster counterclockwise until it stops the 1/4 turn clockwise? is that the correct way to do it?
Old Jun 24, 2005 | 02:27 PM
counterclockwise until you feel SLIGHT resistance! Then 1/4 turn in! If you did it until it STOPED, then your clutch is partially ingaged all the time.
Old Jun 24, 2005 | 07:12 PM
alright, iturned it counterclockwise until slight resistance was felt then 1/4 turn clockwise. so i did it right. so do you think its my clutch plates? it slips from gears 3-5.
Old Jul 4, 2005 | 03:59 AM
Rexkarz's Avatar
Probably need to replace the discs, if You are poor, you could take them out and rough them up !
Old Jul 4, 2005 | 11:10 AM
hondabuster's Avatar
Does your mobil 10w 40 have the energy concerving label on it? If it does, then it has moly in it.
Theres a line of thinking which says having moly in the oil, can lead to clutch slipping.
If the clutch is adjusted properly, and it doesnt slip in the first 3 gears, just changing out the oil, to a motorcycle specific oil ( non moly), might be all it needs.
Old Jul 4, 2005 | 01:36 PM
no the oil not energy conserving and ive used that oil in my fourwheeler and it worked alright so i dont think that the problem. im thinking the clutch plates are shot.
Old Jul 9, 2005 | 03:41 PM
well i found my problem, the springs in the manual clutch were shot. i put new springs in it and its good as new.
Old Jul 9, 2005 | 03:58 PM
good to hear!
ghost civic
Jan 15, 2020 07:43 AM
95wolv
Jul 17, 2015 08:13 PM
ghost civic
Jul 15, 2015 10:48 PM
timster911
Jul 13, 2015 01:57 PM
