Just bought a used banshee???
Old Jun 22, 2005 | 10:07 PM
jon06's Avatar
Default Just bought a used banshee???
I just bought it and i was wondering what all i need to do to it before i take it riding??. like what all gear oil and air filters and anything that i might need to look at and get for it.
Old Jun 22, 2005 | 10:13 PM
crazyfor4wheels's Avatar
Deffinatly!!check your tire pressure!! Dont make the same mistake as me.
Old Jun 22, 2005 | 10:22 PM
midnite's Avatar
Just mix your gas at 32:1 and have fun. Congrats on the buy. Oh yeah use a high quality 2-stroke oil, something like golden spectro.
Old Jun 22, 2005 | 10:34 PM
Hey! thats cool,my friend uses 32:1 in his cr250.
Old Jun 22, 2005 | 10:48 PM
jon06's Avatar
anything i need to do to it or anything
Old Jun 22, 2005 | 10:59 PM
midnite's Avatar
Check the crank case oil, chrck the raidator fluid level, clean the air filter if dirty, and check the tire pressure, then enjoy your purchase.
Old Jun 23, 2005 | 06:35 AM
superevil's Avatar
Well there are a few things,first and foremost,if you just bought it. DEFNITELY Change the gas,coolant,and oil.you never know if the guy who had it before you was an idiot. I would also do a thorough inspection. Check for loose bolts,missing bolts. (my lt250 is known to vibrate the bolts that hold the rim off OUCH!!! and any other bolt that isnt thoroughly secure) I would never go riding on a used quad without giving everything a good ole once over. tire pressure,like the other guy said. I would give a good half hour or so of easy going before i tore it up! My lt250 was a complete nightmare of missing and loose bolts. had regular tap water in the radiator(corrodes badly) and had weed wacker 2 stroke oil in it. HAve fun!!!!
Old Jun 23, 2005 | 07:31 AM
venomaxx's Avatar
Just like superevil said, go over that bike from back to front and then back again. I bought a 96 shee and the guy I got it from swore up and down that it had NEVER been tumbled. Well come to find out after a full tear down of the bike that at some time the frame had been snapped and then welded back together by someone that thought they were a welder and the left side foot peg had been totally sheared off the frame and then jimmy rigged back on.
Just when you think that you have check everything on that bike you had better check again. Good luck with the bike and have fun.
Old Jun 23, 2005 | 08:55 AM
Warrior02man's Avatar
banshee = super cool and fast bike.. have fun man! great purchase!
just mke sure u mix 32:1, and check ur fluid levels.. dun want to run with no coolant.. especially in a banshee!
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
